Filament Storage - Dryers - Desiccant - Etc?
Administrator
Bay Area CA
CR-10, i560 ,MFC-7440N
It's been a while since we've had this discussion. And I don't think we've had any long threads about this.
What are y'all using as filament dryers, storage, desiccant, etc. these days?
For me:
  • Dryer: Rarely need one, but when I do, a food dehydrator.
  • Storage:
    • Vac-bags with ziploc type seal on the top and either a hand pump or electric pump to vacate the air. I also put desiccant in with the filament.
    • Air-tight plastic storage boxes with a ton of desiccant
  • Desiccant: I use the blue-to-pink silica gel beads, and I put them in the microwave on low to recharge them. Gotta be careful not to get them too hot.
I also have a bunch of the cheap digital humidity meters in all my boxes. Usually hovering between 10% - 20%
Epatcola
various
I have a cheap circular food dehydrator with cut out trays that will take 3 1kg spools and go up to 70C. I use it on most new spools and measure weight loss to know it was worthwhile.
I have a load of paper sachets of silica gel and I dry them in the dehydrator. I store all spools in zip lock vacuum bags with about 10g of silica gel. I use vacuum bags because they are strong and seal well. Vaccing them down is a bit pointless from the humidity point of view. 1g of silica gel can absorb all the water in about 15l of saturated air at room temperature so leaving some air in the bag is irrelevant. They fit back in the boxes easier when vacced down though.
I also have a couple Sunlu S1 type dryers modified with circulation fans and PTFE tube outlets. They are not great dryers. I use them as external spool feeders which can keep fussy filaments dry while printing.
Guys, if you intend to print solely PLA or PETG, a food dehydrator is just fine, although dedicated driers are in general more convenient and also accurate regarding temperatures. On the other part, if you want to try filaments much more sensible to moisture consider investing in a dedicated filament drier that reaches at least 85C/185F. Trying to dry PC, PA or TPU at 60-65C is a waste of time and energy.
I just use Desiccant bags in my filament box which I warm up when needed on the nearest radiator for a few hours, and it seems to keep my filament boxes at about 50% humidity, I also use a Sunlo dispenser with built in heather and don’t have any feeding issues with them either..
PLA is quite forgiving regarding moisture.
I use those desiccants with some colored beads that turn from amber to green-blue when they catch humidity. As soon as I see the slightest greenish tint on the beads I dry them in the microwave at medium power for 2 or 3 minutes. That’s enough to revert the color back to amber.
Don't do that with the desiccant inside the fabric or paper bag where it comes usually, The bag would burn in the microwave.
What I do is to discard the original bags and store the silica gel beads in 3D printed containers provided with a threaded lid. This way I can remove the silica gel when it needs to be dried and pour it into a heat proof glass tray that goes into the microwave. When the desiccant is dry and cold I put it back into the 3D container.
Of course those containers should be printed with filament capable of enduring at least 90C. No PLA or PETG. In my case, I use PC,
Brother MFC-L8690-CDW
The polymaker polydryers and boxes get a good name. Initial purchase with the control box is not cheap but additional storage boxes are reasonbly priced. Look out for Black Friday deals maybe?
https://polymaker.com/product/polydryer/
Administrator
Bay Area CA
I'm a bit paranoid when it comes to moisture in my PETG and especially my TPU.
I put the PETG into a very good Ziploc bag with desiccant and remove all the air RIGHT after the print is done.
I do similar with my TPU, but also put it the vac ziploc bag (no air / desiccant) into the original Mylar bag. Again, I know it's overkill, but I've read that some moisture can leak through plastic and also protecting it from any UV.
I’ve had no moisture problems since I switched to these ESun reel dispensers, their trouble free to use with my new setup and hold the filament very dry (20%) for ages, but I still use my large containers to hold my un-used filaments..
ConradH
Canon PRO-100
I'm using a Creality SpacePi X4 because it was on sale for a while and it seems to do a great job. It's winter and my humidity is low, about 40% RH most of the time, but that won't last. I mostly print PLA and PETG. They aren't terribly sensitive to humidity, but I did recently have some issues. I use a Prusa bronze colored filament that suddenly didn't purge very nicely, and it had absorbed more water than you'd expect PLA to absorb. The stuff is actually PLA Blend and I think between that and the pigment, one has to be more diligent about drying it. I also use black eSUN TPE-83A, a flexible material. It needs to be dried well to print nicely. An oddity is that when I first got it, I put it through the Teflon tube and printed with no trouble. After a recent very through drying, the friction was too high to use the tube. I had to feed it into the extruder directly.
For storage, everything is in Zip-Loc bags with a pack of silica gel. I question how good that method really is.
