Epson ET-8550 Bronzing?
pdan
Epson ET-8550
Hello everyone,
I've recently started printing on Epson Premium Glossy photo paper. Previously I only used Epson Matte and got very good prints.
However, on glossy paper I'm getting pronounced bronzing?? Not something expected when using dye inks. I am using genuine
Epson inks.
The only thing I can think off is that PB dye channel has somehow been contaminated with pigment black ink? Perhaps the PB
bottle was wrongly labeled ? Perhaps its something other?
Any thoughts or advice would be greatly appreciated.
Peter
There are several things to consider in this case -
which color(s) is affected - photoblack only ?
do you see a difference with bronzing when you compare a print printed yesterday against a print just recently - the bronzing effect may dry away overnight or reduce the effect.
You may do another test with the ink denstiy - there is an option setting - in the maintenance tab in the extended settings - 'Print density' - reduce it by 20% and reprint a test image to compare.
I'm currently not assuming any ink contamination or simillar if you don't do refill or use other 3rd party ink.
pdan
Epson ET-8550
Thank you for your swift reply!
I would say that it is photoblack only or when the colours are of a lower value. I have dug out an old B/W Northlight image test printed on my once owned ET-7750 and compared it to the same printed on the ET-8550. The ET-8550 print shows strong bronzing, particularly in zones 4 and 3.
I will try the reduced ink load test.
pdan
Epson ET-8550
Just checked: my printer dose not have "Printer Density" option either in 'Settings' or 'maintenance'
Perhaps your printer settings are still on Matte paper ?
pdan
Epson ET-8550
Media setting don't change the options on the 'maintenance' display.
Looking at colour glossy prints done on my old ET-7750 show no bronzing whatsoever, they are much better than the ones made on the ET-8550.
Another oddity is that B/W prints in ABW mode on glossy come out very brown/sepia in 'neutral' setting. In 'cool' setting only slightly less brown.
Which system are you running on ? The Windows driver gives you the option to change the ink density
pdan
Epson ET-8550
I'm on macos using the latest printer driver and firmware. I don't see this in the printer dialogue on the computer or on the printer display panel.
That's pretty bad that you don't have such control over the ink density, that'a typical adjustment on higher end and large format printers.
There is just one vairable to can give a try - the paper type itself - run your test print with a lower quality paper selection like standard glossy or generic glossy or similar - not with premium or ultra.
The paper selection selects a different ink density - lower for lower quality papers.
Please give it a try if that makes a difference at all.
I don't have an ET-8550, but maybe this helps:
