Tony4597
- Jan 20, 2021
- Cheshire, UK
- Epson Surecolor SC P800
FWIW, and bearing in mind I have not tried a guide such as these.
I believe the Z direction (height) can adversely readings due to the thicker your guide base is the greater the cross-talk from adjacent column patches may be. In practice does it really make any difference I just do not know but...
Quote from Graeme Gill (Developer ArgylCMS)
The Munki/i1Studio isn't designed to be spaced away from the paper - the geometry of the illuminant doesn't allow for that.
So it really should be sliding on the paper itself. A "gotcha" is that the instrument has two small rubber pads that
are designed to stop it slipping when taking individual measurements, and these impede smooth sliding. If
you are mainly doing strip reading you could remove these, or if you leave them they will wear down in time anyway[/quote}
