- Dec 27, 2014
- Germany
When you print patch sheets to create a icc-profile you are supposed to let the prints dry for a while - but how much ? There are various different recommendations published in the Internet from 1 hour to 1 day. I did a test with a small patch sheet - 96 patches - on a PE/RC glossy photo paper and measured the color drift over time, I scanned the patch sheet the first time within 10 min after print and then at 1 hour, 3 hours 8 hours and 1 day. The i1 Profile software let you easily measure and calculate color differences between different scans of the same layout, I'm using the deltaE(1976) numbers as the scale for this test - a deltaE of 1 is supposed to be a color variance which an observer can recognize under good/lab viewing conditions. Patch sheets are printed on a 4 color WF2010W with the 106 inks with the matte paper selection
___________________deltaE
10 min to 1h______0.61
10 min to 3h______0,81
10 min to 1d______0,98
These deltaE numbers are the average of all deltaE changes of the 96 patch fields, there are instrument/reading variations combined with actual color shifts, the trend is clear - the most color shifts happen within the first hour of drying time.
If I ask whether I should wait longer than 1 hour I'm getting these numbers
_____________deltaE
1 h to 3 h____0,30
1 h to 8 h____0,52
1 h to 1 d____0,70
It still makes a small difference between the numbers at 1 hour or 1 day but not so much - if you have time to wait just wait to the next day but if you are in a hurry colors have pretty much stabilized and scanning the patch sheet already after one hour will give you a pretty accurate profile, you may do a rescan after 1 day if you want to narrow down the color shift variations.
_____________deltaE
1 h to 3 h____0,30
1 h to 8 h____0,52
1 h to 1 d____0,70
