- Dec 27, 2014
- Germany
- L805, WF2010, ET8550
that's a valid point - the WF-7210DTW has a user replaceable maintenance/waste ink box
You are forgetting the Pro 100/Pro 10 can now be rest, so that is no longer a problem.. But finding one is…In all likelihood, with a Pro-10/Pro-100/Pro-200, the waste inkpad counter would reach full
How often did this happen with your old printers? It takes a long time to fill the ink pads of a Pro-100. There are not many reports that this happened and this is an old printer.In all likelihood, with a Pro-10/Pro-100/Pro-200, the waste inkpad counter would reach full long before printing 10.000 13x19" canvas sheets.
For 10.000 prints of that size it is a full time job on all printers discussed. Estimating a refill of small cartridges 2 times a day, 10 minutes won't change much.Why don’t you look into getting a second hand Pro 100 or Pro 10, they can handle every one of your needs x 10…
I was averaging 2000 prints a day and I never lost a printer due to print volume or pads full, but I did lose one due to ignorance when the purge pump blew off a pipe and failed, and I hadn’t got a clue back then..@The Hat: how many prints/year you made in your heydays with such printers and how long did they last ?
@artprint1 can’t make a proper decision, because there are no printers that go anyway near her requirements sadly.. Maybe choosing two printers might work..I can imagine that it is not easy at this time for @artprint1 to make the right decision.
Maybe you could use the inks from the new G520 and refill carts. With resetter you can always fill them up and then change a complete set of carts. So you start again and again with a full set. Refillable carts for this printer should be very cheap. If your already used carts are transparent you can start refilling these. So you can also look for carts with the biggest volume and use these. Depending how many set you need, you fill them all in advance. Changing always the whole set will reduce ink usage, less cleaning cycles after change, and save a lot time. The ChromaLife100 inks are not bad and you can get constant quality. Aftermarket you have with Precision Colors also a reliable source for inks in bigger quantities.With our current Canon Pixma iX6820, the ink cartridges are so tiny that we're swapping them every 8 prints
I didn't forget at all, but reseting the counter is not enough in this case. The user must clean or replace the waste ink pads. Most people ( including myself ) won't dare to do that. You know too well that it requires disassembling and reassembling most of the machine.You are forgetting the Pro 100/Pro 10 can now be rest, so that is no longer a problem.. But finding one is…
