- Apr 19, 2007
- USA
- Canon MB5120, Pencil
To reiterate, all aftermarket inks fade relatively fast compared to OEM Canon inks, some faster than others. If you want long lasting prints to hang or are selling prints then use OEM ink.
Some aftermarket inks have a better color match out of the bottle compared to OEM inks. Obtaining a custom ICC printer profile may equalize much of the differences in color. The process is you will print out a specific image and mail it back to the profiling business. You will then get a file you install on your computer and then select that ICC profile when you print. Note that an ICC printer profile is designed for ONE specific printer, ONE specific set of inks, and ONE specific paper. Change any ONE of these three variables and your prints may be dissatisfying as you've noted with your image above.
You can guesstimate color fidelity by adjusting the Color Intensity using the Manual Color Adjustment slider in the Canon printer driver that appears when you click to print. You may also be able to compensate with Photoshop.
Forum member PeterBJ has a great thread on color cast correction that may be useful to try. Read the entire short thread.
https://www.printerknowledge.com/threads/compatible-cartridges-and-colour-cast.10956/
When requesting advice on purchases then it is critical you post what country you are in as recommendations often are region specific.
