- Jan 24, 2011
- Kmt. 0.
- MB5150,Pro10s,i3Mk3s+,Voron2.4
I never had real trouble with cyan or magenta. Yellow was the only ink a bit troublesome in my first MB5150. Just small gaps in the nozzle test, but it annoyed me.
As you Maxify users surely know, you have to be careful replacing a cart. My advice is never start printing a regular job right after the machine has primed the printhead. First print a nozzle check. Usually there's cross contamination and an additional cleaning cycle needs to be performed. If you're lucky, the second nozzle test will be fine. If so, then print immediately some pages containing the color of the ink that you replaced. That seems to equalize pressures somehow.
Yesterday, being in a hurry, after replacing the black cart, I skipped the extra cleaning cycle and I continued the printing job leaving the machine unattended for some time. Coming back, I was greeted by the horrible sight of a bunch of pages glued together with blotches of black ink. Another sheet of paper was stuck in the rear. Maybe I over refilled the cart because it never happened this to me before. I needed to perform a cleaning cycle for all four colors and then an extra one for the black before the nozzle check was fine and, of course, I had to remove the sheet of paper stuck and clean the ink spilled on the printing plate.
Maxifys are merciless with careless users.
