- Apr 19, 2007
- USA
- Canon MB5120, Pencil
There is much going on and too many complicating conditions to make an easy determination.
First, the image of printed page against the monitor is next to worthless for diagnosing for a number of reasons. The environmental light is of such a warm brightness that against the very bright and probably uncalibrated monitor who know what colors are accurate or not.
Second, who knows what customizing is done with the current settings of printer/monitor/application?
Quicksand.
time to get back to basics so we all have common footing.
I recommend you either completely reset the printer to Default settings, as if factory fresh out of the box first time installation, or, uninstall every software and driver that came with the printer, reboot, and install again as if the first time.
Follow the instruction in your User Manual to print a Nozzle Check (or whatever it is called for your printer) following the instructions and recommendations of the User Manual exactly. For Canon a simple sheet of Plain Paper and the setting of Plain Paper is used. Whatever your Epson manual says then follow it. Make ZERO alterations to settings otherwise. Use a virgin sheet of paper - nothing printed on it previously.
Print the nozzle check, scan it, crop it and post the image here. Then we can begin to figure out what is going on.
Quicksand.
