- Nov 27, 2010
- Copenhagen Denmark
- Canon MP990
The nozzle check looks perfect to me, so my prime suspect is the paper. I suggest to try another brand of photo paper.
HiHey! Just wondering if you ever worked out the issue / or a fix for this? I'm currently experiencing the exact same problem and have been through all the usual steps for narrowing down the issue. Mine is doing the faded line at the very bottom of the page.
Thank you! I'll give it a tryHi
Yeah i actually managed to fix it by going to the printer utility, on the drop down menu (cleaning is first on the drop down), custom settings and i selected align heads manually and also changed the ink dry waiting time to long - this completely fixed it for me
I hope this works for you, let me know
Here's the latest one I've just done. I'm very new to printing etc so most of what I'm doing is trial and error!Post a Nozzle check, with some history, because if it can print A4 then it's not the printer..?
Let me know if there's anything else you'd like me to post to try and work out the issue!Here's the latest one I've just done. I'm very new to printing etc so most of what I'm doing is trial and error!
Also, as I'm trying to eliminate any other issues that could be causing this - could this error on my PC be something to do with it? Unsure if it's linked in the slightest
Your nozzle check looks perfect, so it can’t be anything to do with the inks, and the only thing I can think of is to slow the printer down by using Quiet mode, and longer drying time and maybe select a different media to print on..Let me know if there's anything else you'd like me to post to try and work out the issue!
