Best practices on first-time Pro-100S ink management
I have also found that changing the paper a couple of times speeds up the drying. It still takes some hours though.
I would think that microwaving the cartridge would ruin the chip.
Yes, of course. In my case, it were BCI3/BCI6 chipless cartridges from the first generation of Pixmas
KasperDM
Brussels, Belgium
Canon IP4500,HP Deskjet 1000,
Hello everyone,
Hope you are doing and printing well.
I have a question regarding the previous posts here: I bought the pre-filled cart set from Octoink, totally sure that was a good choice, but now, at my first refilling moment with these carts, I think I have done something wrong.
Black, cyan, photo magenta and yellow were flashing low ink. So I refilled using the top-fill method. I didn't reset the chips, considering this wasn't necessary for the carts in the kit. First five prints afterwards all went fine, until now - the black cart keeps giving me an 'empty' error and won't print any further. Which n00b mistake did I make?
Thank you very much for your insights,
Enjoy Saturday,
Kasper
Whenever you exchange your cartridge for anything other than a brand new one, you must reset the cartridge chip before you refill, for that cartridge to continue to function properly…
user5800
Pro9500 MkII
Can I ask you if there could be potential disadvantages for this solution in order to avoid purges:
What about opening the cover, removing the power cord, refill everything, putting back the cartridges and turning back on the printer as just a power outage happened? Do purges happen even in this case?
user5800
Pro9500 MkII
Yes, every time… They can’t be stopped… Plus you get an even bigger purge for pulling the plug..
I see, this behavior happens also when turning off normally the printer? Sorry for the additional question :)
