05SpringerMike
- Dec 17, 2020
- Epson 5ECE9D (Artisan 837)
These are detail shots of the test page after running routine maintenance. Brand new Epson cartridges.
Any suggestions?
Did the problem arise when you began using the aftermarket cartridges?I don't recall anything out of the ordinary when the problem began manifesting itself a few weeks ago,
So the nozzle check above is from a single nozzle check printed since you installed the new cartridges?we replaced that cartridge with the new one today, but obviously that didn't help at all.
Swath #5 - Magenta - is two-toned vertical striping. The left verticle strip has a Bluish background while the majority verticle stripe has a Yellowish background. This is why I thought you had swapped positions of the 5th and 6th swaths. Is this "normal" Magenta swath appearance?in the correct order: Cyan, Yellow, Light Cyan, Black, Magenta, and Light Magenta.
Please print a new/current nozzle check, scan, crop and post. It is best to analyze from the most recent information possible.it's been so long since we did a nozzle check
Ahh. OK.The nozzle check I uploaded yesterday was done just that morning, after the new black cartridge was installed.
