Canon IP7270 (Asia model) uses cartridge PGI-750/CLI-751
DHL
Canon Pro-100 & IP-7270
Does any body know that PGI-250/CLI-251 (for North America model IP7220) can also be used in IP7270 printer or not?
Is firmware control the cartridge chipset recognition or something else?
Can I just upgrade the firmware from Canon US into this IP7270 for using PGI-250/CLI-251 cartridges without any problem?
The simplest answer is no, and your best bet is to go with what you have now and just change the cartridge chips to the region you’re in now.. Much more controllable..
DHL
Yes, fully understand now. Chips are hard to be migrated due to the very thin chips board in OEM cartridges. It's a high risk operation.
If you have a problem moving the chips then, buy a redsetter and there won’t be a need to remove them or buy ARC chips in AliExpress and fit them..
But you must continue to use the PGI-250/CLI-251 chips regardless of where you move too..
DHL
I see. Checking in Aliexpress for the chips. Thanks for the suggestion!
