I had to use my The Hat Decoder Ring, a little more detail would have been appropriate,but I think I understand. However, if my first assumption is incorrect then nothing is trustworthy.
1) You are using Precision Colors inks with a Canon Pro 100 printer.
2) You have Epson premium paper, but you do not tell us WHICH premium paper it is. However, you included "1270-2000P " which appear to be two different Epson printer models. That may mean the paper is optimized for those two printer models.
3) You stated there are FOUR different ICM's for Epson premium type papers. This makes me think you are looking at Precision Color's older inkset ICM's:
"Profiles for the Older ( Prior May 2019) PC42G inkset"
This is bcause there are four ICM's on that page and only TWO ICM of r a Premium paper on the newer inksets:
Profiles for Newest ( May 2019) PC42 Signature Edition inkset
The FOUR ICM profiles for the OLDER inksets include the following Premium ICM's:
| Other Papers | Standard D50 Illumination | D65
Illumination | Fluorescent
Cool White | Fluorescent
Daylight | Tungsten
Illumination | Media Setting |
NOTE: The Rows above a little skewed from the Colum headers, so be mindful which "Download" link goes with which lighting/illumination ICM.
What you want to do:
- What type of Premium paper is it - Glossy, Semi Gloss, Luster, or Presentation Matte? Should say on the box the paper came in.
- Next, download the ICM for the lighting you will be displaying the printed image under. - Standard D50, D65, Fluorescent Cool White, Fluorescent Daylight, or Tungsten.
- Install your custom ICM.
- Set your printer's Media Setting to the proper Media Type as stated in the final column above.
- Print. Try different lighting/illumination ICM's if you'd like. Experiment.
