- Jan 18, 2010
- Residing in Wicklow Ireland
After the big wait things seem to be getting back to normal in China, I’ve been receiving the odd package over the past few weeks, and today I got several more, but most of all I got my new 3D printer.
It came already built and I only had to pop in the vertical shaft that holds the nozzle section in place and tighten a few screws and connect the Z motor power plug, and I was running a test print from the supplied SD card, in half an hour..
It will take a bit of getting to use too this new printer, because it's a touch screen operation, and I'm not a fan of this technology but I'll have to soldier on with it, they supply a new look alike CURA Slicer on the SD card for this model printer, probably because it's not covered by any Normal CURA Slicer to date, but the new Slicer works much the same.
The printer was easy to setup and get going, it was only a matter of inserting the SD card (Which is not that easy) and select a file to print from, I choose a food clip and then level the hotbed and it was ready to print, it heats up fairly fast and prints very well, and after that I changed the filament roll and printed the first piece of my standard lamp..
Click to enlarge...It's good to be back in Business, O' the smell of heated filament again...
