Problem with printhead change and E161-403E
Felix H.
IPF6100
Hello!
I am rather new to both printing and this forum and hope to get som help here :)
A few years back I bought an IPF6100 and I have used it every now and then. During the last few months it has not been used and when I try to start it, I get the error message E161-403E and the instruction to "Call for service".
Apparently I need to change the right print head. This would probably ok, but the problem is that I cannot start up my printer in order to get to the menu, which is necessary in order to change the head. Even if I start the printer in "Service Mode", the error message will show and will prevent any further progression into the menu.
So my question is what to do? Can I change the print head without starting the computer? Or can I somehow "bypass" the error message and get into the meny anyway?
Any help is highly appreciated. Thank you and best wishes from Sweden!
/Felix
Hi @Felix H and welcome, it’s not nice when your darn printer won’t let you carry out such a simple task, obviously your documentation tell you it’s a problem with the left hand print head.
To start the process try first to unload the paper if there is any paper loaded, then turn off the printer.
Next Press the Load Navigate at the same time as turning on the printer.
Go to maintenance then select Replace print head and the printer should then allow you to carry out the task, now replace the head and this will fix your problem.
Never replace the print head without using the service mode otherwise it will give you a big headache. Each time you need to replace a print head be sure your maintenance cartridge has sufficient enough space left in it ..
Felix H.
IPF6100
Thank you very much for the fast reply. :) I have tried to start the printer in service mode before. (However, I pressed "feeder selection" & information simultaneously and not "load" & information as you suggest. Perhaps load & information will do the trick?). The printer then starts in service mode, which is indicated by the letter S that appears in the display. Then, while the printer still continues to start, I release the feeder select & information buttons. And before I get to the menu, maintenance, the error message appears and blocks any further navigation. :(
woodenfred
Canon ipf710
Felix H. I have the same problem. What was the solution?
There is a service tech coming next week, but I'd like to clear the error and see if it will plot the 2 drawings I need now.
rcmjr1959
New Printer Member
ipf825
I know this is quite old, but was wondering if you got a resolution to this. I have an ipf825 doing the same thing. Has not had much use lately, swapped computers it is attached to, tried to power up and connect to new computer and got the error. Cant get into service mode without the error coming up. I sure hope you got resolution! Please advise! Thank you
