Problem at print speed
yaghob68
hp m2727
hi . i have printer hp m2727 . When printing (spooling) a file, the file size is increased . See the picture below . The file size of the pdf is 3 MB and the size of the print is 300 MB
please help
what is the problem ? Those 300 MB are the pixelized data for 38 pages, that's not much. The PDF file does not store pixels but the letters as Truetype fonts (or similar) and picture data is compressed. The driver is converting that into a pixel stream which is sent to the printer. You are printing apparently with a rather low resolution/quality. Just calculate the amount of data for one page - with 300 dpi on a 8x11 inch sheet - that's 8x300x11x300x3 for 3 colors ~ 24 MB, probably a little bit less deducting borders, and this is the amount of data per page.
yaghob68
hp m2727
Printing time is very high. Each page is 5 minutes . Sometimes it takes 3 minutes for a 200 kb page to print
How is yur printer connected to the computer ?
yaghob68
hp m2727
network & usb2
usb & network
usb & network
which means what - the printer is connected to an USB connection at a network router which runs some print server functionality ? Or via a shared printer on another computer ? How long is the USB cable ? Can you try to connect the printer directly to a PC-Notebook whatever with a short USB cable and run the same print job ?
yaghob68
hp m2727
I tested with a short cable, but the problem did not resolve.
There was a problem with the firmware update before.
And the printer was not set up.
I contacted the repairer. The printer's motherboard was repaired and the device was restarted.
There may be a problem with the printer's motherboard.
yaghob68
hp m2727
hello sir . i am find problem . i installed only driver and the problem was resolved . But if I do not install the software completely, I can not use all the features of the printer. Does another driver printer work?
Latest posts
