INKJET ARTIST
 - Mar 18, 2019
 - Epson XP 345
The thing are not as simple as it sounds.
You have to knew that the most consumer Canon printers do have 2 - 3 nozzle rows for particular color channel. These rows are different in color intensity or in droplet size. Smaller a droplet the lighter color.
If you go to the best mode then driver shifts primary usage from one droplet size to the other for the same color on paper. That means it is stacking droplets over previous one and in the multi pass way you get the same color but BETTER resolution.
If you go to silent or best resolution mode you will give print head more time for cooling but in the same way you are going to over load an new raw of heaters. So you are turning in an closed loop
Only way to prevent this is that you regularly refill to full your cartridges and check real ink flow in this cartridges. In that case fully refiled ink is used as some kind of heat exchanger. And a heat generated buy inkjet heater is dispersed in ink in ink cartridge.
So if the ink lever is low or you have disabled ink level and you want to empty some ink to the last droplet then you are on the best way to ruin your print head since there is no ink that is going to collect and transfer extensive heat to cartridge.
Same goes to the case if ink flow is low because of trapped air or heavy ink component in sponge in some refillable cartridge after a couple of refill.
For these reasons Epson is by fare better choice
