- Apr 19, 2007
- USA
- Canon MB5120, Pencil
Did you pay your electricity bill?Pro10s redsetters are USB powered.
@Artur5, that’s a real bummer when a chip goes west on you, suggestion:- can you get a PK black chip from a CLl-8 cart and see if that will work, because most of the 9500 chips are the same as the CLl-8’s...Today I got trouble with my Pro10S and it’s all my fault.
Thanks for letting us in on your stupid mistake, maybe it might stop others doing the same...
Another suggestion:- If you have a spare chip any colour will do, try putting that on your PK cart and inserting it, yes it will be rejected but it might cause a reset and then it may except the earlier rejected chip..
Everything is worth a try..
Thanks a lot. A really good idea ... and I'm utterly ashamed that I hadn't thought of it before..Another tip on how to reset the PGl-9 / PGl-72 carts when full..
Turn both the cart and the resetter upside down and then apply the necessary pressure to make contact with the brass pins, if by any chance ink does spill out it can only flow down the cart and mess up your fingers...
That’s a good enough reminder to reset first.... Next time..![]()
@Artur5 : I wonder if you do not overfill your carts, it happens to me too I have to reset a full cart, but I have no ink spill doing so.
Since the carts are physically the same, full weight of OEM is 31.5g on average.
Minus 14g declared ink = 17.5 empty.
What is the weight of your PRO-10S resetted carts when empty ?
Most of mine still weigh over 20g, meaning the resetted chips do not count the full 14g, wich is a minor disadvantage but an additional argument to not overfill.
I'm not optimistic at all about that resetter. I believe is kaput or it wouldn't have damaged the second PB chip.Mr5[/USER]Good luck, what happened to you is not the end of the world, I even think there is a big chance your resetter is not damaged.
I agree....I'm not optimistic at all about that resetter. I believe is kaput or it wouldn't have damaged the second PB chip.
