- Jan 24, 2011
- Kmt. 0.
- MB5150,Pro10s,i3Mk3s+,Voron2.4
Last two days I’ve been dealing with an stubborn clog in the magenta channel of my Pro10s.
The printer had been idle for only three days. I printed something on Monday and everything was fine. Yesterday, before a small print job I decided to do a nozzle check, just in case.. and damn it, the lower part of the magenta stripe showed a massive clog A regular cleaning didn’t help a bit, nor a deep cleaning. No improvement at all.
So I decided to clean the printhead outside the printer. Something that I don’t like at all. Classical procedure: printhead in a bowl with cleaning fluid; paper towels below the nozzles and more paper towels soaked in cleaning liquid covering the inlet ports.
After three-four hours I reinstalled the printhead and a nozzle test revealed a very small improvement. This encouraged me to repeat it but, this time, leaving it overnight. This morning I checked again and improvement was clear. Maybe 60% of the missing nozzles were back. See the pictures below: the one at left after unsuccessful in-printer cleanings. Centre picture after overnight soaking.
Last resource to use was a magenta cartridge filled with cleaning solution and that did the trick. Just installing it the printer did an autopurge, and then I printed several nozzle tests. In the first one the magenta stripe was very faint and in the others totally blank as expected. Finally, after leaving it resting a couple of hours, I've replaced the cleaning cart with a normal one and this time all the nozzles were back in town. See picture at right.
Naturally, after cleanings, deep cleanings and removing/reinstalling the printhead two times, a lot of ink went down the waste pads. Looking at the levels now, possibly 30 or 40 ml. Even for third party ink, the cost wasn’t negligible.
I have two explain that last weekend and up to Tuesday we had very dry weather. It happens here when the Northwest wind blows hard. Outdoors, humidity went from 45% to barely 20% in a few hours. It didn’t last long and inside the house, it wasn’t so dry but I suppose that this played a role in the clog story. Nevertheless, with my Pro9000 I never had a clog after only 3 days of leaving it idle, no matter the humidity. If you ask me why the magenta clogged while the other colors didn’t, who knows ?
This Pro10s was purchased at Amazon four months ago. If needed, I expect that they would have honored the warranty, but it’s a real PITA to ship this massive beast and that would mean to be without a printer for weeks maybe. I couldn’t call them to say that the printer was fine and I just needed a replacement printhead..
To end this tale, rest assured that from now on I’m running a nozzle test every other day, if not daily.
