ninj
- Dec 28, 2011
As it happens I also have some (white) PETG from Real Filament. They vary a lot between manufacturers, so perhaps @The Hat's PETG is harder to work with, but I've had reasonable success with mine. It does take some experimentation to get good results, and my settings might not work for you (thermistor accuracy can vary between printers for example). I use 230C nozzle, 80C bed, and print slower than for PLA, around 40mm/sec. The main problem is stopping the filament from sticking to the nozzle. You then get burnt blobs deposited at random around the print. Try to avoid the nozzle tip dragging through the first layer. You might need to raise the z=0 height slightly above normal (it doesn't need as much "squish" as PLA). Some people cover their heater block with a silicone cover to prevent build up. Sticks well to plain, clean glass, a thin layer of dried Pritt stick, or a dilute PVA coating. Beware that it can stick too well - I've heard reports of PETG taking out chunks of glass from the bed as it cools, though I haven't experienced this myself (yet...). Using an adhesive layer should protect against this.I just put in an order for PETG from real-filament, but you've persuaded me to order a spool of midnight silver from 3dqf as well.
Good luck and please report back how you get on with it.
