- Jan 18, 2010
- Residing in Wicklow Ireland
I’ve no use for Professional profiling.
Whilst most if not all you guys who frequent this forums like to enjoy printing their excellent photos at a substantial cost reduction to OEM inks without comprising on their colour print quality, but I don’t print photos.
When you change or alter any of these set conditions that the printer manufactures have laid out, like your ink or paper then you’re in a whole new ball game, the new Pro printers are a prime example of this.
To reproduce professional prints faithfully when you have deviated from these standard setting you are going to need help from some external sources, and this is where the likes of Colormunki and friends come in and rightly so.
But I learned over time how to reproduce the colours that I need from these small printers by just using their own built-in colour management drivers without having to purchase and install professional profiling software.
My output is done mainly on the same plain and semi gloss copier papers, so I reckon I don’t need the help of a profiler with this type of work, because I mostly print text and graphics, and work in Illustrator or QuarkXPress which don’t use profiles.
I work with the Canon Colour driver adjustments which enables me to use all the same inks and if I need to deviate from one set colour to a particular PMS colour then it’s much easier than switching to professional profile equipment.
I stock two type of ink sets, a set of dye and a set of pigment inks, all dough my printers are very different they will print much the same with a little bit of help from the Canon print driver and a lot of patients.
Now if I cared to print photos for commercial purposes then I definitely would have the Colormunki hardware and anything else that helps make things easier, maybe even Adobe Light Room.
I did in the past use some profiling software to get a particular PMS colour that I required, but that was before I learned how to use the printer driver itself, so it is possible for me to use such professional profile equipment but not very Practical in my line of work..
End.
End.
