- Dec 27, 2014
- Germany
I don't know whether the current service manuals still contain circuit diagrams to that detail showing all the many connections from the nozzles for the conductive elements to the driver/multiplexer chip. The connector pad of the printhead by far does not have as many contact fields as there are nozzles. There is a chip doing the decoding, the nozzle resistors are arranged in a matrix, a line gets connected to the driver voltage - something like 24 to 28 Volt as I remember, and a column gets connected to ground at the same time - for a few microseconds and the nozzle resistor at the crossing point gets active, boils the ink etc. So this chip does not just logic functions but as well power functions switching the voltage to the resistors on and off. So each nozzle resistor has a binary address, but those numbers may not all be consecutive but in groups - by color - by droplet size - physical location in the printhead etc. And it's the matter of the driver/firmware to address the correct nozzles at the right time. And if a particular area in the chip is defunct you get those patterns - half of the color pattern missing or alternating sections missing in the paper black section or worse with smoke coming out of the printhead or other error conditions. It's all not repairable and cannot be cleaned away. Smoke - B200 error etc happen suddenly other than individual nozzles giving up and not printing anymore.
