Another Upgrade to my CR-10...
My next upgrade to the CR-10 will be to add in another lead screw on the right side of the printer to assist and improve the Z axis, after I’ve upgraded the heated platform, I’ll be using Creality parts for the upgrade, they are slightly dearer but you do get all the correct wiring and parts needed.
There is also an upgrade to detect missing filament and power outages but for that you need to change your motherboard to accommodate the extra sensors, I don’t reckon there worth all the extra hassle and cost...
New Lead screw.PNG click to enlarge..
It looks like the vase in the second image has a color gradient from more yellowish to more reddish orange. very attractive. How is that done?
How is that done?
I haven’t got the foggiest idea, but on looking on it further, it’s like a possible reflection from the platform below ?, and if I’m wrong then I’ll have to forgo the cigar this time... :(
Seems there are temperature dependent color changing filaments: https://www.3dhubs.com/talk/thread/color-changing-pla-filaments
Scroll down in the comments for links to the filaments.
Note the Yellow-Orange filament in this link. Looks like the colors used in the vase in your image: https://www.amazon.com/GO-3D-PRINT-Temperature-Changing-Filament/dp/B01LYGCZ7D
You may be on to something about the platform. If the temperature gradient varies between platform, which may be heated, and the ambient temperature of the room, then maybe the yellow color shift is due to warmer temps of the platform?
Seems there are multi-headed extruders to hook up several filaments at once in one printer. These machines tend to be expensive, so somebody designed a less expensive gizmo that feeds different color filaments based on your programming: https://gizmodo.com/this-box-turns-any-3-d-printer-into-a-multi-color-mult-1699332022
Poor man's multi-color printing instructions using a single extruder: https://www.matterhackers.com/articles/how-to-print-in-multi-color-with-a-single-extruder
I have already used two colours in one of my projects, and there’s no reason to stop just with two... ;)
legs-jpg.5884
Emulator
Canon Pro9000 II
It won't be long before you will need a 3D Colormunki to colour profile your filaments and extruder. :)
Administrator
Bay Area CA
CR-10, i560 ,MFC-7440N
@The Hat, which of your upgrades are in response to actual problems you are having vs. preemptive in case there could be a problem down the road?
@Nifty, It’s all pre-emptive on my part, I reckon the platform could do with a bit more stability, and the Z axis may also get problems later from constant use, I reckon there’s no point in waiting till you have a serious problem to fix it, besides the Z axis will be much smoother with the duel motors fitted..
As I’m not going to be printing for some time with it, I’m thinking what else can I do to the beast, it’s such a pity to just leave it sitting there, its much harder to have patience in 3D.... :eek:
Brother MFC-L8690-CDW
Adding the second lead screw is probably a good idea, Creality have done it in the new CR10S I believe.
