- Thread starter
- #21
- Jan 18, 2010
- Residing in Wicklow Ireland
I just used a standard laminating pouch from United Office, it’s an 80-micron plastic coating, you put your paper into the plastic pouch and pass it through a heated laminator, its suppose to protect the paper from moisture, dirt and humidity, it doesn’t say anything about UV or ozone...What is the lamination process? It seems, to me, that it is affecting the inks.
If anybody wishes to know..I'm still unclear about the combined effects of UV and ozone, how to separate them to judge their effects individually
while I’m at it, here’s the way I went about creating the test sheets, I printed 8 sheets of paper, first glossy, photo matte, Premium coper and cheap copier, I did change the media setting for both photo and plain paper samples.
Then I cut all the sheets into four and pasted one piece of each sheet onto a single A4 sheet, this gave me two identical sheets with the four different printed samples of each and the rest of the cut pieces I discarded.
I laminated just one of the print sample sheets, and then stuck both sample sheet in my window...
