replied to the thread
Not sure but I think PrintPrism might work on some un-supported scanners too
Softproofing with both profiles in PS (RC, BPC=on):
Feb 17, 2026
OK here is the second test using a different paper/ink/printer combination: Action Glossy (cast paper) on the ET-8550 dye ink printer...
Feb 17, 2026
ohtoulouz
reacted to
W. Fisher's post
in the thread
Printprism: I have bought it to test its capabilities and quality of the rgb profiles
with
Like
I own a copy of SilverFast Studio AI 9 that I use with an Epson Perfection 600 scanner. It uses a it.8 Version 2 target for a reference...
Feb 17, 2026
W
W. Fisher
Feb 17, 2026
K
knowing
Script for Printer Calibration on Windows, MacOS snd Linux (free to use and modify)
Hi all, Today I tried the Pre-made target: "CM-Interm-A4-2070p-10pages-w13.0mm-14x15_Modified-Atkinson1728-randomized" I go a lot of...
Feb 16, 2026
reacted to
Ink stained Fingers's post
in the thread
with
Like
As much as Epson is using the same printhead across a wide range of printers they'll use as well the same scanning hardware across a...
Feb 16, 2026
I have printed the target on a cheap cast paper of Action with the ET-8550, which should give a different 3D plot. I will redo the test...
Feb 16, 2026
Feb 16, 2026
reacted to
pharmacist's post
in the thread
with
Like
Redoing the test with an earlier printed target on another paper type: First on the ET-8550 scanner: Secondly on the WF-7840...
Feb 16, 2026
Feb 16, 2026
K
knowing
If anyone using the script has suggestions on how the menu for Colormunki or other instruments should be set up with good target...
Feb 16, 2026
ohtoulouz
However, looking at the spec Of the WF-7840 scanner on the Epson website, it not execaly the same specs: (2400dpi max instead of 4800)...
Feb 15, 2026
ohtoulouz
I am sure that there is not that much different scanner hardwares around ! Business is business. If one hardware fits all, it is all...
Feb 15, 2026
posted the thread
in
Printing Photos and Photo Software
I have to test this, but my first impression that by chance I tried to make a profile with PrintPrism with my unsupported Epson WF-7840...
Feb 15, 2026
ohtoulouz
Yes, exactly. There is no scanner restriction. I choose Printprism ET-8500/8550 option and when the Scan2 window open, I choose XP-970...
Feb 15, 2026
