ThrillaMozilla
replied to the thread
Colormunki Photo Jig + Yellow Cast?
Dr. Nick wrote: Using the spotread command I noticed that argyll measures a LAB value of about -93 / 0 / -3 when the instrument is...
Dec 21, 2025
How to use an unlicensed i1Pro spectro with i1Profiler and ArgyllCMS
Tell me first the maximum distance you have between white and white area using the ruler and tell me the distance for example 24 cm, so...
Dec 21, 2025
C
Cassiop38
Epson 378 cartridges and resetter question
yes... i'm currently trusting a 13€ kit of 6 cartridge found on amazon and i'm afraid they leaks at some point. So far so good but you...
Dec 21, 2025
M
mavtop
@pharmacist today i tried to use your enlarged ruler (we used a value to increase the length) to scan using i1profiler v3.1.1 for Mac...
Dec 21, 2025
M
mavtop
if i remember good @pharmacist had troubles after 3/4 refill with the aliexpress cartridge, use the original, i already refilled them 5...
Dec 21, 2025
ilvals
Thank you so much for your reply! I've read your first message several times already. Did I understand correctly that the full command...
Dec 21, 2025
ilvals
reacted to
pharmacist's post
in the thread
with
Like
Standard printer profiles are using the D50 observer at 2 degrees (1931_2) thus: colprof -v -qh -i D50 -o 1931_2 -S AdobeRGB1998.icc...
Dec 21, 2025
Artefil
reacted to
websnail's post
in the thread
HP Firmware lottery - Again
with
Like
In case anyone has an HP printer that has received that joyous of all wonderful gifts, ie: a firmware update over July/August (2022)...
Dec 21, 2025
Dec 21, 2025
ilvals
Friends, please, I really need your help. For more than two months now I’ve been trying to create a profile for Epson L8050/L18050...
Dec 21, 2025
H
hdtvjeff
Canon Imageprograf TC 21 /Lucia TD inks and harvesting inks from 300ml/ 700 ml cartridges
I am looking to refill the CMYK Canon ImagePrograf TC 21 with CMYK ink which is also pigmented but not Lucia based with regular OEM...
Dec 20, 2025
It is not clear to me what printer must be refilled, but I buy GI-56 bottles to refill the cartridges of my Maxify. This works...
Dec 20, 2025
H
hdtvjeff
Also I will be buying Canon OEM GI 26 not third party
Dec 20, 2025
H
hdtvjeff
My goal is to print life-site cutouts of people I know that or maybe 60 long. Perfection is not a requirement. I have Canon image...
Dec 20, 2025
I wouldn't expect some ink to be perfect, but suiting the requirements and I would not expect technical problems with the inks in...
Dec 20, 2025
