H
hdtvjeff
replied to the thread
Canon Imageprograf TC 21 /Lucia TD inks and harvesting inks from 300ml/ 700 ml cartridges
Yikes! I really thought these CMYK inks from GI 26 bottles was the perfect refill for PFI 050 CMYK bottles Now, I am not sure, not...
Dec 20, 2025
The 'Canon TC20/21 - same with the Epson TC3100(X) - are not advertised as photo printers at all, so there is no reason for Canon to run...
Dec 20, 2025
Which black is used on a Canon 1p4300 when printing different material?
I could assume that there are some hidden parameters in a PDF file which may cause the print this way or another way - e.g. is a text...
Dec 20, 2025
H
hdtvjeff
YOU ARE RIGHT, 100 percent Right. the GI-26 is IDENTICAL to PFI 050. Same ink. 132ML bottles, half the cost of pfi 050 70 mml bottles...
Dec 20, 2025
T
thebestcpu
Colormunki Photo Jig + Yellow Cast?
Hi @overstay2057 I use Macs so my thoughts here may not be exactly right. First, this is the interface where you can set defaults for...
Dec 20, 2025
V
videobruce
I've printed one document, then printed a different one just after, one was ok, the other wasn't. Can't make this stuff up. :he...
Dec 19, 2025
1426eav
Epson Stylus Photo R2400 – Adjustment Program Needed
Thanks - I'll give it a try.
Dec 19, 2025
superjudge
Since I had made a lot of improvements in my pipeline before finding out that the PS script was going to bail on me, I back-ported a...
Dec 19, 2025
It's as well with borderless printing on copy paper that the printer switches from the pigment black to the dye black ink, this prevents...
Dec 19, 2025
superjudge
I just started scanning 800 patches, and the PowerShell GUI isn't working for them--it may be introducing additional complexities to the...
Dec 19, 2025
V
videobruce
posted the thread
in
Canon InkJet Printers
FYI, this is one of the 1st series of Canon ink jets with the dreaded 'chip' in the tanks, but unlike the models after these, this are...
Dec 19, 2025
C
Cassiop38
Epson 378 cartridges and resetter question
Really ? I had no luck resetting ARC chips on the 24XL i used for the XP-960 i had. If it's different for the 378 that's great ! I have...
Dec 19, 2025
If you have an EU version XP-15000 then the resetter will reset both original as well as aftermarket on-time reset and auto reset chips...
Dec 19, 2025
H
hdtvjeff
Indeed. Just wish i knew for sure if the Canaon Imageprograg TC 21 used Lucia TD inks as AI says but Canon won't verify CMYK should be...
Dec 18, 2025
You have quite a range of inks you can use, but you would need to run some tests - profiles to verify all your assumptions.
Dec 18, 2025
