A
AmaDeuSbg
reacted to
Ink stained Fingers's post
in the thread
Brand new CANON TM-255 OEM inks - ink scratches really easy from glossy media
with
Like
Give hairspray a try - as a test - just use the regular one not the strong stuff which is weatherresistant etc. You should test various...
Oct 13, 2025
A
AmaDeuSbg
replied to the thread
Thank you both @thebestcpu and @Ink stained Fingers I am located in Bulgaria and sadly all the cut papers I found (there were just 2-3...
Oct 13, 2025
Python GUI to generate TI1 files for ArgyllCMS and convert to i1profiler patch set
I took some time to create a 702 patch target using 128 grey steps with the python script and below you can download the workflow for...
Oct 13, 2025
E
Epatcola
I had a quick look and saw 60 bytes sent for each button press. I expect those 60 bytes mostly contain 31 spectral measurements. I would...
Oct 13, 2025
The strange behavior of i1Profiler in the amount of grey and near neutral patch generating If you choose 1589 patches: alot of grey...
Oct 13, 2025
One thing in your python script: the amount of black patches is not defined but standard set to 4 I see the command window the argument...
Oct 13, 2025
reacted to
crenedecotret's post
in the thread
with
Like
As a followup, if you want to use an X-Rite unsupported device with ArgyllCMS without using i1profiler (say an old ISIS bought off ebay)...
Oct 13, 2025
Hi @crenedecotret : that was some fantastic job you did with help of AI. I have generate a ti1 file and used ArgyllCMS to generate a...
Oct 13, 2025
C
crenedecotret
Oct 13, 2025
reacted to
in the thread
with
Like
Hello everyone... WIth a little bit of AI powered help, I was able to create a method to use ArgyllCMS as a patch generator for...
Oct 13, 2025
C
crenedecotret
posted the thread
in
Printing Photos and Photo Software
Oct 13, 2025
C
ConradH
Yes, I'm always thrilled to do my bit :barnie Anyway, I suspect reading and writing to the CR30 (which I often type wrong as CM30 and...
Oct 13, 2025
E
Epatcola
That would be much more complicated. I envisage a jig like this The CR30 is a loose fit in the jig main part. The collar around the...
Oct 12, 2025
C
ClydeMeneses
which Printer+Scanner with bottled ink shoukd I buy - Epson or Canpm?
I agree, longevity between Canon and Epson bottled inks isn’t a big deciding factor anymore. It really comes down to what you need day...
Oct 12, 2025
The reading can be done too by sending a pulse to the CR30: the ColorQC2 software can perfectly read a patch by pressing on the button...
Oct 12, 2025
