replied to the thread
OK, now I understand the underlying problem. I will regenerate the the ti2 not the use random order and remove the extra data: these are...
Sunday at 9:35 PM
reacted to
x64's post
in the thread
with
Like
Comparing that ti2 and csv to the files we used to design the converter I notice some obvious problems/differences: -You used random...
Sunday at 9:32 PM
x64
Sunday at 9:26 PM
Running almost 3 hours: the process is still hanging: Not sure what is causing it: it does not give an error that some data is wrong...
Sunday at 7:33 PM
reacted to
Redbrickman's post
in the thread
How many of us are still refilling ink cartridges?
with
Like
Like NIfty I gave up on inkjet for normal office printing and bought a laser as I may not print anything for several weeks sometimes but...
Sunday at 7:01 PM
I am struggling with the larger 247 patch target. There is not the same error as previous, but running colprof.exe and the system tends...
Sunday at 4:41 PM
@Epatcola : that is a fantastic design you have made....making it possible to scan miniature patches as well. That will greatly...
Sunday at 3:46 PM
reacted to
Epatcola's post
in the thread
with
Like
Here is a collar and 300mm rule for 10mm square patches. Rule and collar on your 247 patch target scaled by forced printing at 518 dpi...
Sunday at 3:42 PM
E
Epatcola
Sunday at 3:25 PM
yes indeed, likewise my i1Pro1 and i1Pro2 white tile also is bound with a seria number to the device and cannot be exchanged, because...
Sunday at 3:09 PM
reacted to
Epatcola's post
in the thread
with
Like
I noticed the calibration cap has a serial number matching that which the device reports to the application. Our white calibration...
Sunday at 3:08 PM
E
Epatcola
Sunday at 1:44 PM
I will try to reread the target again, because maybe the problem is on my side. Normally the distribution of the test samples should be...
Sunday at 12:58 PM
x64
Something with the gamut mapping the source ICC, when running colorprof with no mapping (no -S/-s) I can create an ICC with that dataset...
Sunday at 12:01 PM
reacted to
Artur5's post
in the thread
Anniversary update on Standard Lamp Mark V..
with
Like
... or dislike it ...:p @The Hat, I expect you're planning to print the new 3D lampost in PLA ?. If you made it from ASA instead of...
Sunday at 11:50 AM
