x64
replied to the thread
Yep that works now, before you rescan, the last remaining step is that the csv needs unique per-patch names that we can match to...
Sep 14, 2025
I think I messed up all the files, so this is the correct set of data: ti1, ti2 and the ti3 that is scanned with a known spectro: i1Pro1...
Sep 14, 2025
This is how the profile should look like:
Sep 14, 2025
Here it is:
Sep 14, 2025
x64
reacted to
pharmacist's post
in the thread
with
Like
I see the reference 228-target.ti3 (with my i1pro1) is not ok. I will upload it again. Please use this new ti3 als a reference to create...
Sep 14, 2025
reacted to
x64's post
in the thread
with
Like
I'm breaking my head over this, using your provided i1Pro1 .ti3 that you made with ArgyllCMS, the resulting icc generated with ArgyllCMS...
Sep 14, 2025
Sep 14, 2025
x64
Sep 14, 2025
finstp
posted the thread
Pro-1 problem - Sorry!
in
Canon InkJet Printers
Hi, I have been trying to recover a Pro-1 printer with an apparent absorber pad problem. The printer is old, mine new from 2015, but has...
Sep 14, 2025
I use this setting: colprof -v -qh -i D50 -o 1931_2 -S AdobeRGB1998.icc -cmt -dpp -D%par1% -C%par2% %par3%
Sep 14, 2025
x64
I get the same flattened pane when processing your i1Pro1 .ti3 with ArgyllCMS. If you get a nice profile with the i1Pro1 .ti3 you...
Sep 14, 2025
actually not, that should not be the case. It should like a inflated pear.
Sep 14, 2025
reacted to
x64's post
in the thread
with
Wow
I'm getting some results, can generate icc profiles from converted csv to ti3. Difference between i1Pro1 vs CR30 seems reasonable, but...
Sep 14, 2025
x64
Sep 14, 2025
x64
reacted to
pharmacist's post
in the thread
with
Like
Not sure this will work, because I think the sample_LOC is defined in the ti2 file, where you might extract from there. Sorry I am a...
Sep 14, 2025
