reacted to
x64's post
in the thread
with
Like
Great, that is the spectral data we need. But can you provide it as a csv like before, the xlsx makes reading more complicated and does...
Sep 14, 2025
replied to the thread
Not sure this will work, because I think the sample_LOC is defined in the ti2 file, where you might extract from there. Sorry I am a...
Sep 14, 2025
x64
Sep 14, 2025
P
pdan
Epson ET-8550 Bronzing?
That's just me thinking out aloud. As I said before, I'm not going to give Epson £700.00 for a printer that uses inferior inks.
Sep 14, 2025
Ohhh, I see an error: the LAB values is BLA instead of LAB...here is the new file: PLEASE use this file (400-700 nm spectral range).
Sep 14, 2025
So I managed to include the spectra data: LAB + spectral data from 360-780 nm and a version with LAB + spectral data from 400-700 mm, as...
Sep 14, 2025
Hi @x64 : Is will try to rescan the target again and include the spectral data from 360 to 780 nm in steps of 10 nm and also the...
Sep 14, 2025
x64
Could you share another scan csv but with spectral data so I can include that for you. Because the CR30 is not included as target...
Sep 14, 2025
Here is the device specs: https://en.chnspec.com/Product/info.aspx?itemid=441&lcid=246&id=228 software is called colorexpert
Sep 13, 2025
W
W. Fisher
Epson 3880 uses different chips in USA and in Europe?
I've been using the Cone chips on a set of refillable carts for a decade on a couple of 3880s that are still running well. The Cone...
Sep 13, 2025
That could be an option - you just would need to swap the bottle tops
Sep 13, 2025
E
Epatcola
The CR10/20/30 are at the bottom of the page I linked. I assume they are the manufacturer or at least closer to them than aliexpress and...
Sep 13, 2025
x64
In my example, the NUMBER_OF_FIELDS is correct: SAMPLE_ID RGB_R RGB_G RGB_B XYZ_X XYZ_Y XYZ_Z (7 fields) Pharmacist introduced...
Sep 13, 2025
Yes I get it....unfortunately there is te sample_Loc that is gone. I have to merge it with the ti2 file I think. No the colorimeter is...
Sep 13, 2025
finstp
posted the thread
Hello
in
Member Introductions
Pleased to find this group. I am trying to revive an old Canon Pro-1 printer, (mine since new) which for various reasons I haven’t been...
Sep 13, 2025
