reacted to
Ink stained Fingers's post
in the thread
You don't need much patches to create a good printer profile
with
Like
Let me mention the DeltaE numbers of the last test - I did in this case compare the patch prints done with the 720 patch profile and the...
May 28, 2025
replied to the thread
May 28, 2025
A
Plugs for Pro1000 carts
Yes and usually free shipping for orders above 10 euro/USD or around two bucks if the articles cost less than 10. 5/32" =3.97mm...
May 28, 2025
Epson P400 Alternative
You may have a look to the ET-8550 - a dye ink printer as an ink tank model and a user replaceable waste ink/maintenance box. Even the...
May 28, 2025
A
reacted to
palombian's post
in the thread
Canon Pro-10 Nozzle Clogged or Damaged?
with
Like
That nozzle check is probably recoverable with good management. Try to view with a loupe or by scanning with high resolution to see the...
May 28, 2025
P
phildemanstr
PRO-1000 - access print head when printer is blocked by B204
Never mind, I got it opened. I successfully unlocked the print head. Thanks for the instructions.
May 28, 2025
May 27, 2025
P
phildemanstr
Hi Bentley, This is great information. However, after removing the 2 screws from the back of the right panal, I am unable to slide the...
May 27, 2025
P
phildemanstr
May 27, 2025
aliexpress might be your friend sometimes they deliver within 7 days.
May 27, 2025
D
dwoolery
posted the thread
in
Everything Else
Does anybody know where I can obtain silicone plugs for 5/32 inch holes drilled for refilling into the Pro 1000 cartridges? Precision...
May 27, 2025
C
Charles218
Yes, 13" is what I am looking for, nothing larger. I originally purchased the Epson over the Canon for the ability to print banner size...
May 27, 2025
I assume that you are looking for a 13" printer if you refer to large format. ? I'm not aware of evidence that an Epson printer would...
May 27, 2025
C
Charles218
posted the thread
in
Everything Else InkJet Printer Related
I purchased my P400 directly from Epson 6 or 7 years ago, at the time it was my understanding that the print quality was excellent, plus...
May 27, 2025
reacted to
in the thread
with
Like
I expect a marginal change for the DeltaE 165 vs. 192 - value only - in the range of reading noise/variations behind the decimal point...
May 26, 2025
