replied to the thread
You don't need much patches to create a good printer profile
I expect a marginal change for the DeltaE 165 vs. 192 - value only - in the range of reading noise/variations behind the decimal point...
May 26, 2025
reacted to
pharmacist's post
in the thread
with
Like
I hope you will report back and see how this target will perform compared to a larger patch size target like 729 or even 2880 patches...
May 26, 2025
May 26, 2025
reacted to
Ink stained Fingers's post
in the thread
with
Like
@pharmasist - it works - I printed your 192 patchsheet on a 10x15 cm card and scanned it with the i1io2 robot - it works !!! - that was...
May 26, 2025
S
Sarah0525
posted the thread
Tried a new marker-free 3D scanner (Trackit)
in
3D Printing Design, CAD, Modelling, Filament, etc.
Hey all, Just wanted to share a quick experience with a new scanner I got to try out — it’s called Trackit by Revopoint, and it’s...
May 26, 2025
wilko
Strange behaviour with aftermaket CL-581 cartridges
Just wanted to elaborate on the need for quality printing and I will always continue with my quest of ink refilling for many projects...
May 25, 2025
May 25, 2025
reacted to
in the thread
with
Like
You got it - it's 192 different colors
May 25, 2025
May 25, 2025
I think I might have found the doubles and removed them. I think these are the last 6 RGB patches (with different hues) before the near...
May 25, 2025
A
reacted to
PeterBJ's post
in the thread
Supportcode 1403 how to deactivate Canon PIXMA TS9550
with
Like
When a Canon printhead begins to fail the printer often shows an error code 1403 that can mean the printhead is overheating. This makes...
May 25, 2025
A
reacted to
The Hat's post
in the thread
Canon Pro-10 Nozzle Clogged or Damaged?
with
Like
The carts are very easy to flush, but you need a special modified clip, that way you can rinse the cart with Window cleaner using a...
May 25, 2025
PaintShop just gives me the number of unique colors - nothing more - no value or location in an image file whatever. But I could find a...
May 25, 2025
OK, I will have a check. Maybe you can tell me which patches are doubles, so I can change them. Thanks for the feedback.
May 24, 2025
reacted to
in the thread
with
Like
Did you check if you have some dublettes with the same gray value along the gray axis - your standard 5x5x5 matrix of control points...
May 24, 2025
