B
Brother46*
posted the thread
Brother MFC-J6530DW - Ink Cartridge Door Open Fault - Re-Set?
in
Member Introductions
Gooday All' Brand New here .. Going thru significant Drama' today, trying to setup my otherwise Steady Eddy' Brother MFC-J6530DW...
May 14, 2025
K
karama
replied to the thread
ix6780 printer bricked after resetting wast pad count
Sorry for the inconvenience. I will upload zip format file or binary bin file if possible tomorrow.
May 14, 2025
T
thebestcpu
reacted to
The Hat's post
in the thread
Vintage HP/GretagMacbeth Eye-one Pro spectrophotometer: still sealed
with
Like
Let me see what I can do with it for you..
May 14, 2025
reacted to
The Hat's post
in the thread
with
Like
May 14, 2025
websnail
You can open it with 7zip.
May 14, 2025
I have found a 3D model that does a better job than the one from HP: now I have to find somebody who can print it for me :oops:
May 13, 2025
K
karama
posted the thread
in
Canon InkJet Printers
Hello guys. I have a Canon IX6780 printer works good until a few days ago. Code 1700 appears and I used reset software to clear the...
May 13, 2025
H
Hogwild
posted the thread
Envy 4520 - do driver updates and/or firmware updates limit cartridge choices/brick anything?
in
Hewlett Packard HP InkJet Printers
Hi: I just came across a used Envy 4520. Did a black self-test page, and it came out mostly okay. However, Windows 10 22H2 didn't...
May 12, 2025
A
AmaDeuSbg
What are the best practices for laser-engraved bamboo without burn marks?
Hey, There are test grids which you can use to find best settings for engraving on the desired materials. The test grids are just...
May 11, 2025
T
thebestcpu
reacted to
pharmacist's post
in the thread
with
Like
I could finally could hold of imatch 3.6.2 that can be downloaded and did work with my i1Pro1. The nicest thing was the ability to use...
May 11, 2025
May 11, 2025
ThrillaMozilla
Epson Ecotank ET-7750 keeps saying rear tray is out while trying to print
It may have sent you directly to PayPal. I sometimes see that behavior, and it's probably normal. It depends on a setting somewhere --...
May 11, 2025
ThrillaMozilla
1. Check that you told it what try to use before you pressed the "print" button. Double check. 2. Check the print queue. There could...
May 11, 2025
C
crenedecotret
Converting Spyderprint 225 patch target to i1Profiler
@buxiaozizai.com Looking at some documentation you may be right. That's bizarre. I ended up with the 0-1 file because printtarg...
May 10, 2025
C
crenedecotret
Hi.. this is totally normal for argyllcms. The original script works correctly. You can use r g b values, convert them to TI1 with my...
May 10, 2025
