B
buxiaozizai.com
replied to the thread
Converting Spyderprint 225 patch target to i1Profiler
Thanks for your share. I found a small error in this script.The argyllCMS .ti1 file XYZ scale is 0~100,but the script generated XYZ...
May 10, 2025
L
Lothman
reacted to
Ink stained Fingers's post
in the thread
How many color patches are needed for a (good) profile ?
with
Like
I made another test to compare profiles with based on different patch sheet counts and the impact onto actual prints. I did this - - I...
May 9, 2025
L
Lothman
reacted to
pharmacist's post
in the thread
with
Like
I think the Colormunki/i1Studio/Calibrite method using the 50 + 50 patch method is actually based on these findings. The difference is...
May 9, 2025
ThrillaMozilla
Epson ET-8550 Velvet Fine Art Paper settings uses Pigment and Dye Black
Yes, you're right, of course. There's just too, too much to write at the moment. I'm not an expert at digital photo printing. The...
May 9, 2025
ThrillaMozilla
Or, for a crude method that can be used anywhere, I would just wet the print. If ink bleeds, it's dye. Then soak it in water to check...
May 9, 2025
T
thebestcpu
reacted to
x64's post
in the thread
Vintage HP/GretagMacbeth Eye-one Pro spectrophotometer: still sealed
with
Like
I have been using that scanning table and slider for a while and I'm not impressed by it. The board itself is fine but the slider is not...
May 9, 2025
T
thebestcpu
Hi @ThrillaMozilla To solve you particular problem, it might have been better to start a new thread as it might get buried here. That...
May 9, 2025
x64
reacted to
pharmacist's post
in the thread
with
Like
May 9, 2025
x64
reacted to
in the thread
with
Like
May 9, 2025
x64
May 9, 2025
bplaman
Hello. To see if pigment ink is being used up when printing a photo print, you need to: - turn on the printer (if it was not turned on)...
May 9, 2025
ThrillaMozilla
This is an almost desperate situation for me. I sort of gave up printing years ago because the blacks were blocked up. And now I have...
May 9, 2025
T
turnpaper
What are the best practices for laser-engraved bamboo without burn marks?
thanks in advance for any help
May 9, 2025
T
turnpaper
posted the thread
in
Printing Photos and Photo Software
Hey everyone, I’ve recently started experimenting with laser-engraving bamboo products like cutting boards and bamboo coasters...
May 9, 2025
B
Bentley
PRO-1000 - access print head when printer is blocked by B204
He guy's little update, we have put a new printer head in the printer, and start the printer, we had 3 time a error, we shut done the...
May 8, 2025
