Tony4597
reacted to
Epatcola's post
in the thread
Using Claria Ink with Entry-Level Epson Ecotank - is it possible?
with
Like
If you are only doing 'some printing' and you think Claria ink will be a benefit why not buy a cartridge printer like the XP-8700? At...
Apr 25, 2025
replied to the thread
Epson ET-8550 Velvet Fine Art Paper settings uses Pigment and Dye Black
https://www.dpreview.com/forums/post/68235087
Apr 25, 2025
T
thebestcpu
I had not seen Keith Cooper's video (or that part of his video), in which Jose Rodriguez indicated that this topic was covered. I asked...
Apr 25, 2025
E
Epatcola
Keith's opinion is how well VFA mode works depends on the paper. Some good some bad. The VFA mode mixes some pigment black in the...
Apr 25, 2025
This is something for matte papers. I ordered several packages of Brilliant matte paper (the one that Keith Cooper has recently tested)...
Apr 25, 2025
Fried Chicken
posted the thread
in
Epson InkJet Printers
Jose Rodriguez points this out in this video: Where he's quoting something Northlight Images must have published, but I haven't been...
Apr 25, 2025
reacted to
Ink stained Fingers's post
in the thread
Converting Spyderprint 225 patch target to i1Profiler
with
Like
I did this over the last days - I used the i1Profiler parameters for a 702 patch sheet as provided above by @pharmacist with the extnded...
Apr 25, 2025
Many thanks for the update. Good to know that there is hardly any difference. However: the ET-8550 has gray ink: this might influence...
Apr 25, 2025
Apr 25, 2025
E
Epatcola
Apr 25, 2025
I must admit that I'm a kind of lost what the actual quesiton is, the ET-8550 runs on dye inks by product design; but using a product...
Apr 25, 2025
Tony4597
Is it possible to detail your intended application requiring high fade resistance and your intended substrates, assuming photo papers...
Apr 24, 2025
L
Lothman
reacted to
thebestcpu's post
in the thread
Star Chart Resolution Tests of the Epson P900
with
Like
Note: I just added the PPI vs. Circle diameter table that somehow did not transfer over with the initial post I ran resolution tests...
Apr 24, 2025
Emeios
reacted to
Tony4597's post
in the thread
with
Like
I am curious so have to ask the question why buy a particular printer and then use the 'wrong ink' for that model as specified by the...
Apr 24, 2025
Emeios
Thank you for your answer! Indeed, I forgot to mention the paper, I had this in mind but didn't mention it this this post. In my case...
Apr 24, 2025
