replied to the thread
Converting Spyderprint 225 patch target to i1Profiler
Many thanks for the update. Good to know that there is hardly any difference. However: the ET-8550 has gray ink: this might influence...
Apr 25, 2025
I did this over the last days - I used the i1Profiler parameters for a 702 patch sheet as provided above by @pharmacist with the extnded...
Apr 25, 2025
E
Epatcola
Using Claria Ink with Entry-Level Epson Ecotank - is it possible?
If you are only doing 'some printing' and you think Claria ink will be a benefit why not buy a cartridge printer like the XP-8700? At...
Apr 25, 2025
I must admit that I'm a kind of lost what the actual quesiton is, the ET-8550 runs on dye inks by product design; but using a product...
Apr 25, 2025
Tony4597
Is it possible to detail your intended application requiring high fade resistance and your intended substrates, assuming photo papers...
Apr 24, 2025
L
Lothman
reacted to
thebestcpu's post
in the thread
Star Chart Resolution Tests of the Epson P900
with
Like
Note: I just added the PPI vs. Circle diameter table that somehow did not transfer over with the initial post I ran resolution tests...
Apr 24, 2025
Emeios
reacted to
Tony4597's post
in the thread
with
Like
I am curious so have to ask the question why buy a particular printer and then use the 'wrong ink' for that model as specified by the...
Apr 24, 2025
Emeios
Thank you for your answer! Indeed, I forgot to mention the paper, I had this in mind but didn't mention it this this post. In my case...
Apr 24, 2025
Emeios
reacted to
Ink stained Fingers's post
in the thread
with
Like
Using the 114 ink instead of another dye ink is not a problem, print quality does not just depend on the inks but very much as well on...
Apr 24, 2025
Tony4597
Apr 24, 2025
Tony4597
reacted to
in the thread
with
Like
Apr 24, 2025
Apr 24, 2025
Emeios
posted the thread
in
Epson InkJet Printers
Hello, I've searched the forum but couldn't find a clear confirmation regarding my question. TLDR: I'm planning to buy an entry-level...
Apr 24, 2025
W
Wats234
Canon MG6850
I found a service manual a pdf in Japanese, I think, and tried pdfguru.com to translate it but failed. So it was all guess work.
Apr 23, 2025
T
thebestcpu
Vertical line indentation down prints xp-970
That was a good test. You have tried the basics, so it appears some debugging is needed. As part of debugging and locating the source...
Apr 23, 2025
