YAAW - Yet Another Argyll Wrapper
riclin
Melbourne, Australia
Canon Pro-10S, Canon iP8760
Did some more testing. It's only the -S switch which gives the differences in chartread output/behavior. I measured the printed target in YAAW and in ChromIQ and both results are nearly identical. The helpful meant warnings from YAAW brought me on the wrong track. Sorry about that. Now I can concentrate on the quality of the profile.
As I mentioned, the -S switch just reduces warning and error messages - it shouldn't actually impact the quality of the read per se. You might want to have a play with the most current version to which I have some default settings for i1 and 3p instruments - they generate useful looking targets although the proportions look a little unusual - note that they have not been tested IRL. Also, based on your earlier observations, the -H chartread switch now defaults to off for anything other than the CM device - let me know whether it being off changes the read experience:
https://drive.google.com/file/d/1GgbzhyTyIdKH28yU0LIH8G5pB_Jv1JIs/view?usp=sharing
Pick the device at the top right hand corner then choose the patch density at "Patches" - if selecting from the dropdown options at the right edge of the Patches field, then Paper size is autofilled.
r.
rjanowsky
Germany - Northern Ruhr Area
Epson SC-P600, HP Envy 4525
Did some testing with the INSTRUMENT_LAYOUTS. Checked out a set with 484 patches on one A4 page. Only change under "Additional printtarg Args" was: -a 0.95 to scale the size of patch fields and spacers a little bit down. The resulting print could be easily measured with the i1pro device. With this setting as base one can do a two (968) or three (1452 )page layout.
rjanowsky
Finally I found the error:
[2026-07-11 16:36:01] Running: targen -v -d2 -f 484 -G -e 4 -B 4 -g 28 -n 0 -N 0.5 -V 1.0 -l '' -c none EPS_Test_OEM-Argyll_i1_484
Running targen with the -c none switch, results in a complete other whitepoint in the .TI12 files:
APPROX_WHITE_POINT "128.335403 100.000000 34.800696"
[2026-07-11 17:33:09] Running: targen -v -d2 -f 484 -G -e 4 -B 4 -g 28 -n 0 -N 0.5 -V 1.0 -l '' EPS_Test_OEM-Argyll_i1_484
Running targen with an empty -c switch results in:
APPROX_WHITE_POINT "95.106486 100.000000 108.844025"
In the first case all values are massively off (about 100∆E and more). Lot's of warnings in YAAW. In the second case everything went smooth. The resulting profile is excellent.
riclin
Very interesting! Good find Ron. On reflection, I must admit that I found issues that I thought may have been related to the "-c none" switch too and in earlier versions of yaaw inserted a test that masked out the -c switch if no preconditioning profile had been selected. In a more recent code cleanup, I removed the test and simply used the "-c none" argument which is what the targen documentation states as correct. From your experience, it appears that that mask did in fact help. I'll dig out the old code and reinsert it - the additional code was nominal but I was trying to clean out any redundant code that had crept in during testing.
Thanks for that. It's interesting that the "-c none" code worked OK for me but not for you. Possibly a subtle difference between how Argyll treats the CM vs the i1? Or perhaps a difference between ArgyllCMS versions? - what version are you running? I am using Graeme Gills most current distribution - v3.5.0. Please let me know what version you have - and if not the latest and you feel inclined, see whether the problem remains with ArgyllCMS 3.5.0. (https://www.argyllcms.com/)
r/
