martin0reg
When the colormunki software prints the first test chart, ONE single patch in the last row comes out pink instead of blue!
In the middle of the last row you can see blue-yellow-blue on the monitor. If I set the printer on some standard paper, the patches will come out more or less saturated, not totally different. But if I set the printer to "NO color correction", which is the correct setting for profiling, one of these blue patches on the monitor prints out PINK!
Result: the last row can not be scanned, always ending in a red error frame.
I have already reinstalled the printer driver, and some more, also tried saviing as pdf. But even with the pdf test chart the R800 will change this little blue patch to pink, if set to "no color correction ... aaararrgggh...!!
OS is windows, printer is epson R800.. the error came out of the blue, have done many profiles with this same OS and printer before.
The wrong colored patch prints out, whenever the printer driver is set to "no color correction"
Most astonishing, that the wrong patch will be printed out of the colormunki software, but also out of pdf viewers, after saving the chart as pdf.
Anybody out there, who can help?
I have posted this problem also on dpreview, hopefully here are some more colormunki experts, who may know this bizzare error, or can explain..
