Why can't you clean JUST one colour?
OM2
UK, London
When cleaning cartrdiges under maintenance, you can clean the all colours, black or just colours
If you've got a problem with just one single colour, then you have to WASTE a LOT of ink cleaning ALL colours
Is it possible to clean just the single colour?
Thanks
Omar
No, unless you have a different set of cartridges filled with water or some other innocuous fluid to substitute for the cartridges you don't want to drain.
Concerning your title: contact Cannon.
Redbrickman
Brother MFC-L8690-CDW
Thanks
Omar
Ahhh... I wonder why the manufacturers designed the printer like that?
Could it be they want to sell you more ink ;) Naw... they wouldn't do that would they :idunno
Just as well ink is cheap for us refillers!
Tudor
Cluj-Napoca, Romania
Epson L800, 1400; ML-2165W
When cleaning the printhead you have 3 options because there are just 2 pads. To be able to clean any colour individually you would need as many pads as the number of cartridges/colours your printer uses (4,5,6,8,10...). Then you would need a lot more tubes leading to a much bigger pump. Why would any manufacturer do that? Just so you can buy less ink? This is their business: INK. Printers are given as a bonus...
fotofreek
San Francisco
The good news is - by refilling you don't have to worry about the amount of ink "wasted" in the cleaning cycles. You can also be happy that the cleaning cycle is keeping ALL of the nozzles clear.
