Why Active Negative Pressure Matters More Than Print Speed
alex123
super A 808 DTF printer
We’ve been testing long production runs on our Hanrun UV-H9060 setup, and one thing became obvious:
Many print issues are actually caused by unstable ink pressure, not the printhead itself.
On some traditional pouch-based systems, we saw:
  • random nozzle deflection
  • white ink inconsistency
  • air bubbles
  • occasional ink dripping
After switching to an active mechanical negative pressure system, long-run stability improved significantly.
The biggest difference was pressure consistency at the nozzle level.
Results:
  • cleaner small text
  • fewer nozzle dropouts
  • more stable white ink output
  • better consistency during 6–8 hour jobs
The multi-zone vacuum platform also helped reduce PET film lifting and acrylic movement during printing.
Personally, I think stable fluid control matters more than advertised print speed in industrial UV production.
Curious what others here are using:
Passive pouch systems or active negative pressure?
