- Thread starter
- #21
arw4
- Sep 20, 2006
- Surrey, England, UK
- Canon MX925 plus a few others
Ah, now that is interesting and useful information. Thank you for that.That's pretty easy - the black ink type selection goes by the paper type you select in the driver - normal paper - pigment black, same for matte papers - glossy , silk, semiglossy etc papers are used with dye black inks. There may be some tricky deviations from that rule with some Canon printers - e.g. if you select automatic duplex printing the driver switches to the dye black, or if you print borderless on normal paper it may switch as well to the dye black. The ink selection is not context dependend of your document you want to print - like using pigment inks for text and dye blacks for photos on the same sheet - no.
So, following on from what you say, if I were to print text and photograph on plain paper (remember this is theoretical!) then the blacks in the photograph would actually be produced using the pigmented black, and not the dye black? This is certainly food for thought. So which gets selected for high resolution coated paper. I like using this stuff for a lot of my printing tasks because it's great for text, graphics and photographs.
As for printing sheet music, I have found through trial and error that the best results are obtained by using the "standard" quality setting on high quality plain paper. It seems to produce a deeper black than if printed using the "high" quality setting in the printer driver.
