- Dec 27, 2014
- Germany
- L805, WF2010, ET8550, T3100X
I'm using i1Profiler/Publish to create profiles , with an i1io table for a quicker scan, I recently migrated from Profile Maker.
OBA's won't impact the gamut volume really, they impact the white point and whatever is linked to it like the gray axis, but any significant amount of ink in the saturated areas will cover up the OBA impact. And even more, those brighteners fade away pretty quickly. I did some quick tests here
https://www.printerknowledge.com/threads/optical-brighteners-and-their-fading.11650/#post-98254
The CR674A HP glossy paper does not contain any of those, o.k. - you don't like glossy papers....
Yes, I do some mixing, I just order CMYK inks, dilute LM and LC from M and C, and mix red and blue for the R800. Not using real pigments for red and blue, but just a mix to keep the printer running should reduce the gamut somewhat in those regions and not enhance it. I'm not inclined to pay the same price for regular inks and light inks just with a higher contents of solvents but less pigments. And inventory keeping is simpler with less ink colors. (although I have to admit that I have a few more inks - dye and this and that type...and leftovers from tests ....)
That's the status on my side, it might be interesting to understand why you apparently get smaller gamuts with your 3880, is it the inks , the printer/driver, the papers - I don't have an idea.
You might compare your profiles with those measured by precisioncolors for the 3880 and their inks and papers
http://precisioncolors.com/E9B3_ICCs.html
You are probably not using those papers but similar paper types should show some similarities in their profiles
