Hello dear members
Printer Model:MP 540 multifunction printer
Cartridgesriginal canon cartridges
Ink:refilled Wox Brand through top fill method using another hole i made with pin
Problem:
my main problem is with light levels of Magenta color being not printed.my printer has 3 levels of Cyan and Magenta color in Nozzle Check Pattern(NCP) test page and the problem was seen a month ago when i started to use the print after it was left for about 6 months disconnected out of power in a corner.a big mistake i made.i think i can call the levels:dark Magenta -light Magenta -lightest Magenta .
1-i did some cleaning and deep cleaning,taking NCP tests.there was some clogged nozzles and light Magenta didnt(both levels) print.
2-i came to this site and learned that i could wash my printer's head under strict current of water and i did so.it solved the clogged nozzles completely and the light Magenta printed after a few cycles but the lightest Magenta problem still remained.weird thing was that my BK color started to have some white lines in second NCP test after washing the head!
3-i tested the purge system and tried to clean it with 98percent alcohol because i couldn't find the mentioned Windex in my country.
i flooded the purge system with alcohol and it stayed there for more than one minute(no leakage i think) and when i closed the cover and opened it after a few minutes,the alcohol was gone,so there seems to be no problem with purge system or leakage in it.
4-after trying to clean it with 98% alcohol the lightest Magenta came sometimes but after one or two NCP tests,it disappeared again.after leaving the printer for 24 hours or more i could see the lightest Magenta again but after 1 or 2 NCP tests it was gone.if i made a deep cleaning it was gone again.
5- 4 days ago i put more alcohol(two days and everyday 4 time i flooded purge system with alcohol). today i saw that i can see lightest Magenta again but it disappears after 2 to 3 cycles of NCP test.the difference today is that if i make 1 or 2 head cleaning it will come back for another 2 cycles or i can wait 5 to 10 mins instead of 24 hours to test and see the lightest magenta again.also if i try to print a photo it will have very unnatural color and light magenta starts to disappear alongside the lightest magenta when i make NCP test.so as you see the problem is really unstable and both light magentas,specially the lightest one appear and disappear again as if i have a very small storage of this colors that runs out of ink rapidly.
unfortunately i can't post images now.system says reduce them to 0
please help me to solve this problem.this one is really driving me to an asylum!
thank you all
Problem:
thank you all
