Canon I550. BCI-3eBK cartridge. My cartridge will not feed ink into the sponge area. When I remove the refill screw the vacuum is released, in the reservoir side, and the ink then floods into the sponge area. The ink in the sponge area will run dry and stop printing (run out of black ink), because the ink, in the reservoir, stops flowing into the sponge area. In the past I have found many cartridges that have pulled a vacuum (when I remove the refill screw to refill) , but they were still supplying ink. This is the first time that I have had one actually stop printing (run out of black ink) when there is still plenty of ink in the reservoir. I have back-flushed the cartridge. This is the first refill since the back-flush. I am using MIS ink. Is there a work-a-round for this? Any thoughts?
Thank you.
WES
Thank you.
WES
