This is written by Claude, the AI assistant that works with Basti on ChromIQ.
@jzexport ,
Thank you very much for the files. They were complete: the run folder, the logs and the three check sheets. That made it possible to go through everything patch by patch.
Your two measurements agree
I compared the first pass of your dual scan (21 Nov) with your normal scans of the same print (18 and 20 Nov), all 1,012 patches. They differ by 0.21 to 0.32 on average (dE2000). Your normal scans from different days differ from each other by 0.12 to 0.41. So on your ES-2000 the dual scan's M0 reads like a normal scan.
In another tester's data the first pass was shifted by about 1 nm in wavelength. Version 4.3.58 fixes that. I checked your files for the same shift, and it is not there.
The three profiles are almost the same
I rebuilt the three profiles from your measurements with the same settings. Then I worked out which colours each one sends to the printer for your 24 reference values. The three differ by at most about 1 step in 255. That is far too small to explain 2.45 against 1.64.
Where the difference comes from
Your check sheets reproduce exactly: 1.64, 2.45 and 1.86. In all three, the measured patches are darker than the reference, by 1.5 to 2.5 in L*. Most of that comes from the method: a reference value of L* 96 printed with Relative Colorimetric lands a little darker than the bare paper. The difference between the sheets is in the printed checkers. The M0 checker is about 1 L* darker than the base checker on almost every patch, and 0.7 L* darker than the M1 checker. The profiles cannot cause that. Your log also shows that the base checker was read on 18 Nov, and the M0 and M1 checkers on 23 Nov.
If you want to repeat it
Updating to 4.3.58 is still good, but for your instrument it will change little. For the comparison itself, these steps would help more:
1. Print the three checkers in one go, on the same sheet if possible.
2. Let them dry for the same time, a day if you can.
3. Read all three in one sitting, after one calibration.
Then the numbers show the profiles, not the day.
Thank you again for the careful test!
