[Tool] ChromIQ – a macOS and Windows GUI for ArgyllCMS printer profiling (v4.2.0)
Thanks for your thoughts @Im-back-Arno :)
I think it is always a matter of making the best without going to the most extremes. Generally, the more patches the better, but what you get in improvement is less and less the higher it goes. Some swear to closer to 3000 patches, maybe because they can and have an i1iSis for A3 pages. We were contacted by a lady from Red River, where we added their patch set into the presets in ChromIQ. Their standard patch set to profile all their papers is 2052 patches, so that might be an indicator in the industry.
Take also a look at this post, where I compare @pharmacist's 1944 patch preset with my own that is in the list of presets: post-149535
To your comment on a one-pager for control: We have designed a workflow in ChromIQ that allows regular control measurements of a profile (we call it a verification run), which then outputs a report, from the tool "Measurement Report" in the tools menu.
Attached is an example report made on demo data, as I do not currently have any real data measured over time to get all the trend-graphs.
And here is a screenshot of the Measurement Report window for the attached report:
Sebastian and I hope the community can test this feature and report back the results... There are many options to customise limits for each metric checked, and there are 20 different metrics to choose from. Here is a view of the setup window that defines all the metrics and thresholds (all 20 does not fit into one screenshot, as the window scrolls):
The Help Card "Getting Started" in the Welcome to ChromIQ window (question mark icon on top-right corner of the app) gives an overview of the workflow in a diagram. I recommend having a look at that. Here is a snapshot of that diagram:
Cheers,
Knut
Hi Knut,
Thanks for the additional info. Around 2,000 patches it is!
Indeed, I did read about the options to do control runs versus time and will try to include that in my workflow once I get the hang of it all and settle on a standard calibration. Will report back on progress and findings on the control workflow when it’s running.
Thanks!
Arno
Hi Knut,
Thanks!
Arno
Sounds great! Thanks...
Just as a curiosity, to give some more backbone to the near-neutral patches topic.
Red River gave us the ti1 patch sets that they user for profiling, as mentioned before, and are thus public and available in ChromIQ. Looking at the 3D plots for, shown below, you can see they use a lot of patches near-neutral ramp, adapted to follow their paper's profile, but much less patches in a circular pattern around the centre neutral-grey axis, and also stopping at the lower black end. The 3D cube plots for the 1944 patch set presets posted earlier use much more patches around the neutral axis (in two circles) and follows all the way down to black. I think ChromIQ's method is more thorough, but only tests could reveal the truth about that. The red river patch set was also manually made by the company, while ChromIQ delivers something the market has not had at all for free use, a patch generator that can create these awesome patch sets that previously only super-high-end high costing software previously could deliver anything close to, if I am correct...
Cheers,
Knut
I am taking a break with my i1Pro1/2/3 targets (those are ready for A4 and I will proceed with Letter later on).
For the moment I am experimenting with the Colormunki/i1Studio spectro. Since this device reads with 50 Hz it is (compared to the 100 Hz i1Pro1 and the 200 Hz i1Pro2) I am playing with a particular elongated patch set that has a length of 15 mm (twice the length of the 7.5 mm patch width of the i1Pro1/2/3 targets). This way you can scan with a reasonable speed over a row similar to the i1Pro1/2/3 while taking the same amount of measurements per patch colour:
Since the patches are very narrow, you will need a 3D printed scanning jig to scan with it:
@knut: do you think this is a good idea for supplying some extra targets using this concept ? One A4 can house 300 patches with this concept, so I can do a 300, 600 and 900 patch target to be integrated in ChromIQ ? I am using a modified TC2.83 target (added extra grey steps up to 300, which I have named TC3.00) for this target.
Hi again,
I have already supplied many presets using this principle. You can see them in the preset list with names ending with "Fast reading speed" and "Slow reading speed". Currently, there are 6 presets for Slow Reading Speed and 8 for Fast Reading speed for the whole range of below 100 patches (for verification only) and up to 2142 patches.
You should really try those out first, before making your own... All the Colormunki/i1Studio presets have especially been made for someone wanting to use a ruler and the quirks that this instrument has. The reading speed is taken into account.
Here is an example for preset "A4-612p-3pages-Portrait-w10.0mm-Fast Reading Speed"
Also, you don't have to have your 3D printed scanning jig. A normal ruler works just fine, and the presets I made have helper markers at the page edges to you can align a ruler easily.
Cheers,
Knut
OK many thanks for the upgrade, so it is not needed. I am working on the Letter targets now. Is a combination of only the ti1 and the corresponding json file enough for a preset or do you need the tif-files and the ti2/ti3 files included in the preset package ?
Anyhow: I will supply you the 2 extra Colormunki/i1Studio presets to be included. Take care with a ruler for those narrow sized patch targets: the Colormunki/i1Studio surface underneath can scratch the patches of the adjacent patches when scanning a specific row. I have experienced this in the past with some delicate papers (with pigment ink) and while scanning specific row, some patches of the adjacent row were scratches and damaged, making the target worthless, hence I now always use a scanning jig.
