[Tool] ChromIQ – a macOS and Windows GUI for ArgyllCMS printer profiling (v3.8.0)
itsab1989
Epson ET 8550, Canon Pro 300
  • CM-Expert-A4-882p-2pages-w7.5mm-21x21-SpyderHighQ.TargetPlusGrays-Randomized.zip
  • tc918-grays.ti1.zip
thanks, at the moment busy at work, I will have a look later and report back.
itsab1989
The zip file was flawed somehow. This one should be better.
CSP
Canon Pro 1000
hi,
first thanks itsab for your great work ! I did test your tool yesterday and run into some issues I would like to report
1. printing from chromIQ with an canon pro1000 and the lates driver for Tahoe 26.5 does apply some unwanted corrections which look very much like a applied printer profile. PS has the same issue but printing from the canon print and layout software and print-tool works, in print-tool color matching is greyed out btw.
2. the guided refine process broken and selects wrong strips
itsab1989
Hi! Thanks four feedback!
For the printing issue: are you printing with the macOS printer dialog option or the the other built in print menu? You can change between those two in the settings window on macOS. It is pretty hard to nail this down. I tried back and forth to find a solution for this and for my Epson ET 8550 it seemed to work (I measured patches of a testchart I printed with different programms and in ChromIQ the results were the same). But I am not on Tahoe so maybe that can make a difference.
For the other issue: where did it go wrong exactly? Do you have the quality report saved? Which strips should it have flagged and which were actually flagged? Do you habe a screenshot or the log file maybe? This would help.
Edit:
This is Claudes take on issue 1 so far:
For Issue 1 (most useful first):
1. The Pro-1000 PPD + option list. Run and paste:
lpstat -p # to get the queue name
lpoptions -p <QUEUE> -l
1. and grab the PPD at /etc/cups/ppd/<QUEUE>.ppd. I want to see what Canon
calls its colour-matching / colour-correction option and its "off" value.
2. A captured "good" job. This is the gold standard. Put the queue on hold,
print a chart from Print-Tool (the working case), then inspect the spooled
job's options in /var/spool/cups/ (the c##### control file). That tells us
exactly which key=value Print-Tool sets that we're missing.
3. chromiq.log after a print using the native-dialog setting — it logs the
resolved printSettings and whether the no-CM lock verified, which tells me if
the PPD scan found Canon's option or not
