jackson
While following this topic:
http://www.nifty-stuff.com/forum/viewtopic.php?id=1254
I printed out a CD (Canon IP5000) and seen that it had no yellow in the graphic.
Pulled the cart (a third party, not Hobbicolor) and noted that the reservoir was 75% full.
Held it over the sink, squeezed gently, but no ink appeared at the outlet.Pulled the tape back from the vent, checked it with a pin to verify it was breathing then opened up the fill hole.The ink started flowing.
Does this mean it was plugged with bubbles?It has been refilled a few time before without any issues.I had given it the 'squeeze and release' test just before putting it in the printer (yesterday).
I hooked it up to a tube and forced water through the outlet, while the water came clear after a few seconds, the sponge still appears orange/yellow.This isn't what I expected inasmuch as in the last time I tried this procedure (a cyan) the sponge turned whitish after a few seconds.
Perhaps a peculiarity of yellow saturated sponges?
Any comments/theories welcome.
