leopardmoth
- Sep 18, 2010
First off... I have learned a lot lurking about on this forum!! Thank you all!!
My Dell A960 finally kicked the bucket after years of abuse, so I need a replacement. I've been looking at mainly Canons, but I couldn't find one that fit all my requirements. This is what I need:
Must handle 110 lb cardstock with no problems, and be able to print photos on it without soaking the paper.
Must have 4-5 separate tanks/cartridges, since I'm done with dealing with a tri-color cartridge.
I must be able to refill the tanks/cartridges.
Must have scanner/copier, but not necessarily an ADF or fax.
Must not be an HP (the software makes me insane).
I have tentatively settled on the Lexmark Prevail Pro705 because:
It can handle cardstock up to .025" thick, which, if I'm not mistaken, is about .009" thicker than 110 lb cardstock.
It has 4 separate cartridges, which I think I can refill, since there is refill ink available on atlanticinkjet.com (is that good ink? Used it with my Dell.)
Has a scanner/copier. It also has ADF and fax.
It is not an HP.
Its UI sounds similar to the Dell's, which I liked pretty well.
It has a front loading tray which accommodates even the cardstock! This makes me willing to put up with the extra bulk of the ADF which I almost never use.
Lexmark made the Dell printers, so I figure if I liked the way Dell printed on cardstock, I should like the way Lexmark prints on cardstock.
If I need to, I can get replacement cartridges easily, even at WalMart (unlike Dell... and these are cheaper, too!).
I do not need absolute top-quality photo printing. I need to print ~25 family calendars on 110 lb cardstock every year, some photos, and a good bit of regular printing.
Does my choice sound reasonable?
Does anybody have a better suggestion that won't break the bank? (I can get this printer for $130.)
It is not an HP.
